2010 Mercury Milan Premier, ECM/Inputs/Outputs Waveform
Throttle Actuator motor pattern when fed "direct" 12V /- (not pulsewidth modulated by pcm)- bad commutator is obvious
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Chris from New Jersey |
| Engine | 3.0 L / 6 cyl / FLEX |
2010 Mercury Milan Premier 3.0L
