2009 Audi A4 Quattro, ECM/Inputs/Outputs Waveform
Posted to the Waveform Library on 11/11/2018
Channel 1: CKP Channel 2: Capacitive pickup on the #1 coil Channel 3: Intake CMP
Taken at idle. The cam timing system was not disabled.
Counting the two missing teeth, the cam signal goes high 16 teeth before the high point in the crank signal.
2009 Audi A4 Quattro 2.0L
Engine2.0 L / 4 cyl / GAS
Trans6-speed AutomaticTransaxle (Electronic)
Component,
Component,
