2009 Audi A4, Engine/Propulsion Document
Updated procedure for checking chain timing on 2.0L TFSI engine. Because of the tooth design on the crank chain sprocket, it can easily slip, and the marks are only visible with the sprocket removed.
| Trans | 0-speed AutomaticTransaxle (Electronic) |
2009 Audi A4 2.0L
