2014 Chrysler 300 C, ABS/Inputs/Outputs Waveform
Known good rear wheel speed sensor wave form. This was taken with the key on, back probing the sensor signal wire with positive lead, negative lead on body ground, while spinning the rear wheel by hand with vehicle on the lift. Original issue was a code C0037...
| Engine | 3.6 L / 6 cyl / FLEX |
2014 Chrysler 300 C 3.6L
