2014 Ram 1500 Laramie, Engine/Propulsion Photo
Posted to the Waveform Library on 10/15/2018
Tonewheels with missing pieces of the magnet will still allow the engine to crank over and you may also read a valid RPM signal in the PCM data. However, due to the gap, the ECM is unable to determine Cam/Crank synch and will not start.
Charles from California
2014 Ram 1500 Laramie 3.0L
Engine3.0 L / 6 cyl / DIESEL
Trans8-speed AutomaticTransmission (Electronic)
SubsystemEngine/Propulsion
