Secondary ignition showing a fuel fouled spark plug
Posted to the Waveform Library on 10/3/2018
During a WOT snap, the left spark plug is fuel fouled and the spark is arcing between the center tip and then along the inside of the porcelain to the plug housing. The spark plug's burn voltage on the right is good
TECH: TSB?
TECH: TSB?
