2015 Hyundai Sonata GL, Ignition Waveform
Posted to the Waveform Library on 10/2/2018
The blue CH A is a 2 wire dist pick up coil on COP 4 at idle, with an intermittent misfire caused by a dripping injector, The red CH B is another 2 wire dist pick up coil on COP 2, with no misfires, The green CH C is the First Look Sensor transducer in the int...
2015 Hyundai Sonata GL 2.4L
Engine2.4 L / 4 cyl / GAS
Trans6-speed AutomaticTransaxle (Electronic)
SubsystemIgnition
Component,
TECH: TSB?
SubsystemIgnition
Component,
TECH: TSB?
