2007 Ford F-250 Super Duty Lariat, Engine/Propulsion Video
This is a pressure test to determine the cause of fuel mixing with coolant on a Ford 6.0 diesel. I built a tool to plug the bottom hole, cycle key and filled injector bore with fuel then pressurized cooling system with only air. Watch for bubbles!! I almost ga...
| Engine | 6.0 L / 8 cyl / DIESEL |
| Component | Other, |
2007 Ford F-250 Super Duty Lariat 6.0L
