2006 Dodge Ram 2500 Laramie, Fuel Supply Waveform
Got no start 5.9 cummins, used wps500 on return fuel line, and low amp clamp on cyl 1 injector, firing order 153624 I am guessing the lower the hump the more return that injector is passing, I decided cyl 2 was passing the most, blocked off cyl 2 and it starte...
| Engine | 5.9 L / 6 cyl / DIESEL |
| Subsystem | Fuel Supply |
2006 Dodge Ram 2500 Laramie 5.9L
