2007 Saturn Relay 1, ECM/Inputs/Outputs Waveform
CH A COP amps, the 6 multi strike has a negative 5A spike, from the secondary spike into the primary coil, CH B the normal secondary has 8.5kv but the 6 multi strike shows a 30kv spike
| Engine | 3.9 L / 6 cyl / GAS |
2007 Saturn Relay 1 3.9L
