2014 Hyundai Elantra Coupe GL, ECM/Inputs/Outputs Waveform
CH B is the PCM PWM control of the VVT actuator volts, CH C is the VVT actuator's pintle opening when I tapped the control wire to ground
| Trans | 6-speed StandardTransaxle |
2014 Hyundai Elantra Coupe GL 2.0L
