2006 BMW 530xi, Engine/Propulsion Waveform
Scoped electric water pump on 2006 BMW that overheats. pump has 2 powers and active data on data bus. Ground was also tested but not in this waveform. Looks like pump tries to turn on but fails. This pump has a brushless motor that is pwm controlled.
2006 BMW 530xi 3.0L
