1986 Jaguar XJ12, ECM/Inputs/Outputs Waveform
This is hooked up to the fuel pump relay ground wire from the computer, the car was hard to start or no start most of the time. it ran lean with good fuel pressure. the fuel would stay running all the time with key on. it had a bad computer.
| Engine | 5.3 L / 12 cyl / GAS |
| Trans | 0-speed AutomaticTransmission |
1986 Jaguar XJ12 5.3L
