1986 Jaguar XJ12, ECM/Inputs/Outputs Waveform
This a current ramp of an injector, car ran lean because of bad computer. Noticed fuel pump would stay running with key on as well,Pulse with should be around 3 ms and 6 ms crankint starter relay sends a signal to ecu to enrichen the mixture. Also if that wire...
| Engine | 5.3 L / 12 cyl / GAS |
| Trans | 0-speed AutomaticTransmission |
1986 Jaguar XJ12 5.3L
