2003 Dodge Caravan SE, Engine/Propulsion Waveform
Cranking in-cylinder compression waveform from a cylinder with a large chunk missing from the exhaust valve (2 valve engine). TDC has been identified by careful observation of the pressure changes. The typical EVO event area has been identified (140 ATDC-C, 40...
| Engine | 3.3 L / 6 cyl / FLEX |
2003 Dodge Caravan SE 3.3L
