2013 Ford Escape SE, ECM/Inputs/Outputs Waveform
Exhaust Cam timing with crank and compression. This 2013 Escape had suffered bent valves due to a timing belt failure. After replacement of the cylinder head, with a used part the engine would not start.
2013 Ford Escape SE 1.6L
