2016 Toyota Corolla CE, ECM/Inputs/Outputs Waveform
CH A Air Fuel sensor amp draw on the initial crank to start, CH B Air Fuel sensor blue wire voltage from the PCM, CH C batt volts on start, CH D MAF WOT snap
2016 Toyota Corolla CE 1.8L
