2007 Jeep Wrangler Sahara, ECM/Inputs/Outputs Waveform
CH A CMP, CH B CKP with 1 missing ckp toggle, causing the pcm not to ground a few coils, which causes the idle to dip low, CH C COIL 2/5 PRI VOLTS, CH D COIL AMPS
2007 Jeep Wrangler Sahara 3.8L
