2007 Jeep Wrangler Sahara, ECM/Inputs/Outputs Waveform
CH A CMP, CH B CKP with the RPM Math channel is pointing to the 1 missing toggle in the ckp, 714 rpm, CH C 2/5 coil pri volts, CH D missing coil amps after the missing ckp tooth
2007 Jeep Wrangler Sahara 3.8L
