1984 Mercedes-Benz 380SE, Ignition Waveform
CH A coil wire secondary from idle at 5kv,to a WOT snap at 11.6kv, CH B coil pri volts, CH C coil amp dwell changes from idle to the WOT snap throttle, CH D cyl 1 sync
| Engine | 3.8 L / 8 cyl / GAS |
| Trans | 4-speed AutomaticTransmission |
1984 Mercedes-Benz 380SE 3.8L
