2007 Jeep Wrangler Sahara, Ignition Waveform
This is from the PSD file in my first post, CH C is the good 2/5 pri coil volts when cyl 5 spark plug is firing, CH D is the good 2/5 pri coil amps when cyl 5 spark plug is firing well
2007 Jeep Wrangler Sahara 3.8L
