2007 Jeep Wrangler Sahara, Ignition Waveform
I turn the engine off, I disconnect the cmp sensor and after cranking for awhile, it runs perfectly, with cyl 2 spark plug firing, CH B 1,4 coil primary, CH C good 2,5 coil primary, cyl 2 spark plug is firing, CH D good coil amps
2007 Jeep Wrangler Sahara 3.8L
