1997 Toyota Camry CE, Engine/Propulsion Waveform
CH A idle MAP volts zoomed in x4, CH C WPS500 measuring, comparing each cylinder's intake stroke's vacuum pull to 20" vacuum, CH D cyl 1 sync
1997 Toyota Camry CE 2.2L
