1998 Honda CR-V EX, ECM/Inputs/Outputs Waveform
1998 Honda CRV 2.0L - Channels are labeled on the left side of the capture. Capture has: CMP, TDC, CKP, Coil Primary Current, B to Coil, and PCM -> ICM. Engine is running at idle.
1998 Honda CR-V EX 2.0L
