2009 Ford F-250 Super Duty FX4, ECM/Inputs/Outputs Waveform
Blue is B2 CMP sensor Yellow is B1 CMP sensor There was indeed a bent tab on the B1 cam [...] has been straightened, as you can see here there is no short or low amplitude pulse anymore. The amplitudes are different however. B1 CMP is a new Motorcraft sensor. ...
2009 Ford F-250 Super Duty FX4 5.4L
