1995 Ford Explorer Limited, BATT/Charging/Starting Waveform
CH A battery cranking, charging volts, CH B starter, alternator amps, CH C engine block to battery negative ground voltage drop
| Engine | 4.0 L / 6 cyl / GAS |
| Component | Other, |
1995 Ford Explorer Limited 4.0L
