2009 Ford F-250 Super Duty FX4, ECM/Inputs/Outputs Waveform
Here you can see the bank 1 CMP sensor in yellow at the sensor, the bank 1 CMP sensor in green at the PCM and the bank 2 CMP sensor in blue . Note the small single pulse in the bank 1 CMP sensor that does not match the single pulse on the bank 2 CMP sensor in ...
2009 Ford F-250 Super Duty FX4 5.4L
