2006 Ford Escape XLT, Engine/Propulsion Waveform
Posted to the Waveform Library on 12/26/2017
CH A, the pcm is keeping inj 2 on for 87ms, sometimes 188ms, CH C bad relative compression, flooded cylinders, CH D WPS500 on the dipstick tube showing the blow by pressure from cyl 2's compression blowing by the fuel washed piston rings, into the crankcase
2006 Ford Escape XLT 3.0L
Engine3.0 L / 6 cyl / GAS
SubsystemEngine/Propulsion
