2008 Chrysler 300 Limited, ECM/Inputs/Outputs Waveform
CH A ckp, CH B cyl 2 running compression as the engine is going into a snap throttle, CH C inj 2 is firing on the closed intake valve before the EVO and the inj 2 is also firing when the IVO
| Engine | 3.5 L / 6 cyl / GAS |
2008 Chrysler 300 Limited 3.5L
