1995 Buick Riviera, ECM/Inputs/Outputs Waveform
Check engine light and P0341 cam crank error. As you can see, failing sensor. Also of note, the pid cam/crank error showed 50. After replacing sensor, the pid read 1.
1995 Buick Riviera 3.8L
