2001 Nissan Maxima GLE, Engine/Propulsion Waveform
CH A FLSE cranking, showing a repeating cylinder's exhaust stroke's high pressure, indicating a cylinder with a valve issue, causing a misfire, CH B erratic relative compression amps, CH D WPS500 in the purge hose, to the intake, with one cylinder's repeating...
2001 Nissan Maxima GLE 3.0L
