2001 Chevrolet Silverado 1500 LS, ABS/Inputs/Outputs Waveform
This is the ground circuit taken at the frame and the connector at the EBCM. A volt drop test of the ground circuit. Yellow is at the connector. Green is at the frame.
| Engine | 5.3 L / 8 cyl / GAS |
| Condition | Unknown |
2001 Chevrolet Silverado 1500 LS 5.3L
