2001 Chevrolet Silverado 1500 LS, ABS/Inputs/Outputs Waveform
This is a look at the ground circuit for the EBCM. The green trace is hooked to battery ground while the yellow trace is at the ground wire at the EBCM. Ground wire is on the two pole connector with the main power supply. I have no idea if this is OK. My po...
| Engine | 5.3 L / 8 cyl / GAS |
| Condition | Unknown |
2001 Chevrolet Silverado 1500 LS 5.3L
