2011 Ram 1500 SLT, Engine/Propulsion Waveform
Posted to the Waveform Library on 11/1/2017
Trying out my DIY Piezo differential pressure sensor. (firstlook) P0302, misfire #2. Red trace is coil #2 primary, Blue trace is my home built sensor. You can see the pressure pulse 180* from the ignition pulse.
Exhaust valve barely opening, popping back int...
2011 Ram 1500 SLT 5.7L
Engine5.7 L / 8 cyl / GAS
Trans5-speed AutomaticTransmission (Electronic)
SubsystemEngine/Propulsion
