2011 Ram 1500 SLT, Engine/Propulsion Waveform
Trying out my DIY Piezo differential pressure sensor. (firstlook)
P0302, misfire #2. Red trace is coil #2 primary, Blue trace is my home built sensor. You can see the pressure pulse 180* from the ignition pulse.
2011 Ram 1500 SLT 5.7L
