2011 Toyota Corolla, BATT/Charging/Starting Waveform
CH A 10.9 batt volts cranking, CH B engine block ground voltage drop to batt neg, CH C starter amps, CH D starter sol pull in winding draws 23.5A for 22 ms and thje hold in winding draws 8.2amps
2011 Toyota Corolla 1.8L
