2006 Ford Escape XLT, Engine/Propulsion Waveform
CH C relative compression amps, CH D, oil is added into cyl 2 then a pressure transducer is connected to cyl 2 and the compression is now 200 psi
2006 Ford Escape XLT 3.0L
