Ignition coil testing
Posted to the Waveform Library on 6/29/2017
I made this many years ago to test ignition coils on the ford vans when doing a tuneup to look for bad coils. Make sure b is hooked up correctly or u have weak spark. Not all fords have b on sam pin. I used an old gm distributor module and pick up. Set kv to...
