2006 Ford Escape Limited, Engine/Propulsion Waveform
![]() ![]() CH B is a First Look Sensor pressure Transducer on the dipstick tube cranking, showing the pressure pulses in the crankcase from the cylinder blow by gases, CH C relative compression amps, CH D WPS500 pressure transducer in cyl 2
Engine | 3.0 L / 6 cyl / GAS |
Subsystem | Engine/Propulsion |
Component | |
Condition | Known Bad |
2006 Ford Escape Limited 3.0L
Component | |
