Damaged pistons in the calipers from pad install error
This guy did his own...but installed the smooth inboard on the outboard position ...and put the outboard (with "pins") in the inboard position...these "pins" gouged the pistons and caused a bad pedal until they seated ...actually cracked the pistons to a degr...
