1992 Oldsmobile Achieva, Ignition - Primary Waveform
Engine was only running on 2 cyls. Coil secondary ohms were about the same, primary resistance was 1.4 ohms and 1.3 ohms. 2-3 coil would not jump anymore than about 5K gap on an adjustable spark gap tester. That coil got replaced.
| VIN | 1G3NL5439N |
| Engine | 2.3 L / 4 cyl / GAS |
| Trans | 3-speed AutomaticTransaxle |
1992 Oldsmobile Achieva S 2.3L
| VIN | 1G3NL5439N |
