2001 Chevrolet Astro, BATT/Charging/Starting Video
First section is of vehicle not charging. Vehicle then starts charging after restart. Second section is key off, key on engine off, and then crank/start (has alcohol interlock). Had 3 fault codes; P0562, P1637, P1638. When failure present code P1637, P1638 ...
| Engine | 4.3 L / 6 cyl / GAS |
2001 Chevrolet Astro 4.3L
