2008 Ford F-150 XL, ECM/Inputs/Outputs Waveform
Camshaft sensor Crankshaft sensor sync. One waveform represents a bad sync-waveform, and the other is correct. The correct phase stopped the code P340 "recurrence". Correctly phased when the green channel 2 hall effect rise at the 7-9 point in the yellow chan...
| Engine | 4.2 L / 6 cyl / GAS |
2008 Ford F-150 XL 4.2L
