2003 Dodge Ram 3500, Fuel Supply Waveform
This capture has been synced to an injector even while measuring the pulses in the injector return flow. The lower pulses ended up being the injector with high return flow. The test was performed during the Pressure Override test in the scan tool and measuri...
| Engine | 5.9 L / 6 cyl / DIESEL |
| Subsystem | Fuel Supply |
2003 Dodge Ram 3500 5.9L
