2009 Infiniti G37, Engine/Propulsion Waveform
No start cam codes. trigger moved on the sprocket. This has a pressed on trigger. This vehicle had both rotate about 1 tooth on both.
| Engine | 3.7 L / 6 cyl / GAS |
| Trans | 7-speed AutomaticTransmission (Electronic) |
2009 Infiniti G37 3.7L
