2011 Volkswagen CC Highline, ECM/Inputs/Outputs Waveform
Posted to the Waveform Library on 3/20/2016
Channel 1 (Yellow) Shows CMP Signal. Channel 2 (Green) Shows CKP Signal. Vehicle would not start after a broken rocker arm replacement. Further inspection showed that cam sprocket shifted on the shaft causing incorrect cam timing. Camshaft is a built-up style ...
2011 Volkswagen CC Highline 2.0L
Engine2.0 L / 4 cyl / GAS
Trans6-speed StandardTransaxle
