2001 Toyota Sienna LE, ECM/Inputs/Outputs Waveform
Channel 1 is the CKP sensor and Channel 2 and 3 are the CMP sensors, can't remember which is which. This vehicle was setting codes p1346 and p1351. Found previous shop had install timing belt off 1 tooth on the crankshaft. I left the cursors in to help identif...
2001 Toyota Sienna LE 3.0L
