2004 Toyota Echo, Engine/Propulsion Waveform
Engine cranking test, fuel was disabled. First look sensor hooked to brake booster vacuum line and low amp clamp around cylinder 1 ignition coil.
| Engine | 1.5 L / 4 cyl / GAS |
2004 Toyota Echo 1.5L
