2009 Chevrolet Suburban 1500 LT, ECM/Inputs/Outputs Waveform
Posted to the Waveform Library on 2/4/2016
Yellow = CKP, green trace is #1 coil control. This was taken at idle with tool reporting 18 degrees advance. each tooth on crank reluctor wheel is spaced 6 degrees apart. The second cursor should be lined up close with TDC #1. Used this to trouble shoot cam cr...
2009 Chevrolet Suburban 1500 LT 5.3L
Engine5.3 L / 8 cyl / FLEX
Trans6-speed AutomaticTransmission (Electronic)
ConditionKnown Good
ConditionKnown Good
