2009 Mini Cooper, Engine/Propulsion Waveform
Posted to the Waveform Library on 2/2/2016
This is a shot off of a mini cooper with multiple misfire codes, Channel 1 is with a first look sensor into the brake booster vacuum hose and channel 2 is a low amps clamp around ignition coil on cylinder 1. We traced fault to carbon build up on the valves.
2009 Mini Cooper 1.6L
Engine1.6 L / 4 cyl / GAS
Trans6-speed AutomaticTransaxle (Electronic)
SubsystemEngine/Propulsion
ComponentOther
ConditionUnknown
ComponentOther
ConditionUnknown
